- 13 Nov 2007
Looks fine on mine ... just don't sit with your nose on the screen!
With TV sizes ballooning it can't be long before 1080p ceases to be the top end of standard HD.
Ive been running mine out of native res for months now like an idiot and just found out. Problem is that the ratio is not 16:9, how can I create a custom resolution?
My dell has 1:1 mapping as well as fill option - set 1080p as the screen res in windows, set the monitor to 1:1 and voila ... 1080p with massive borders!
I have the HPZR24W which is 1920x1200 and that will stretch 1080p video (i.e. if you do 720p or 1080p YouTube fullscreen) but in my case it doesn't matter since I watch films on the TV, or if it's an HD YouTube video I think warrants watching big I'll just use my Apple TV's YouTube thing and use the iPhone to write the name down with via Remote rather than the remote the ATV comes with.
If you only have a monitor as an 'all in one' then it's probably best to compromise and get a 16:9 1920x1080 one since you won't have any problems then.
There's no reason to change the resolution in windows. Pretty much any media player out there will upscale/resize automatically (if needed) and keep the aspect ratio the same (add black borders if needed).
By changing the resolution in windows, you are effectively doing the same thing, except the upscaling/resizing is taking place in your monitor instead of the graphics card. The end result is the same.
fine for a movie but try doing that for a game if you like a wider aspect ...
but its not any wider, just thinner?
However, I am used to this now so anything smaller is now no good lol!
