Oppinions on this BMW 120d?
It's horrible. The first gen 1 Series was cheap and nasty inside, and looks it. That particular one has a horrendous spec and basically looks terrible.
You need to really want a BMW badge quite badly to want one of those.
[TW]Fox;18168880 said:
2007 was the refresh.
What is 'the ladder' and why do you need to 'get on' it? :confused:
The ladder that ends with a 7 series :)
With that kind of budget you'll get a better (but older) E46, but yes, it appears that the "badge" is the only thing drawing DJMK4 to them. A golf probably would suit just as well.
Not at all
Thing is you can say Golf but im just pointing out cars are always a risk, loads of cars have common faults, its just how you deal with stepping around or finding a solution for them.
My Golf basically is in hibernation with the electrics at the moment, why? because I cant be arsed fixing them as they keep going wrong...
Something quite common on the mk4 golf
