I received my HAF X and can happily confirm that all intakes have a filter![]()
HAF X has a 2x120mm fan grill.
I was quite confused by the fan grill being on the underside of the case at first. Following the instructions, it suggested you face the PSU intake upwards (i.e. draws air from inside of your case), but if you put the cable duct in, it blocks air from getting into the PSU! I've never seen a PSU intaking air directly from outside the case. I am a bit concerned it will attract a lot of dust though because of its proximity to the ground.
