£700 SandyBridge?
6 Nov 2002
The rig will be used for gaming, so far I have....
Just need a CPU cooler and a graphics card. What would people recommend? I won't be paying postage and the "novatrise" code will be used. I will also be getting the 20% VAT back from the MSI board. So if you can make it under £700 after that go ahead :D
EDIT: Also if you were to swap something out what would it be and why?
Definitely change the HDD, thats an eco drive, its low power and quiet but not very fast, Id normally say look at a Samsung F3 but theyre not in stock atm so try the Seagate Barracuda 7200.12
You could save a fiver get the Geil RAM which is just as good
CPU cooler look at the Titan Fenrir Evo
GFX wise you can look at either an NVidia 460 1 gig or ATi 6850, I think they should both bring you in around £700 with the VAT back things, both have similar performance so its upto you
the 6950 is great card, I was trying to keep in budget but if youre willing to spend a little extra you cant beat the 6950 for price/performance really
You can unlock the 6950 to a 6970 too so if you can stretch that little extra you won't be dissapointed!
