Cleaning a FF sensor DIY Wet method - RESULT!
Caporegime
20 Oct 2002
Wish i was in a Ramen Shop Counter
Isn't that hard after all.
I noticed there were 2 bit of dust when I shot some quick HD films whilst in Rome, they were shot at F/7.6 or something, I seldom shoot at that aperture so I never knew. I knew there's bound to be some dust as I've had one 5D over a year, one for 6 months, changed lens countless times in weddings so it is not unexpected. As its a new year I thought i give it a clean. What was scary is the FF sensor is BIG, it is a lot bigger than the 30D to clean but it's the same principle so I had a go.
I cleaned both, both shot at F/22
1st 5D result
This one is pretty much perfect I think, I can't see any dust.
edit - found one! Top right on the edge, really small !
2nd 5D result.
By the time I done this the clouds had come out, but i waved it to create movement...I can see a tiny dot on the top right, but its F/22 and it doesn't show at the normal aperture, this 5D actually took me about 2 tries (I first cleaned it 2 nights ago) before I got it like this...annoying, at one point I made it dirtier! lol
That's money saved! :)
Oh, I got my 35L calibrated.
Focused on the Moss, F/1.4
This is how i did it.
Cling Film over the table. It does 2 jobs
1 - It attract the dust near the surface to it, so it removes some dust from the air
2 - Its cleaner than your table, no matter how hard you try to wipe it.
The guide I followed is this one.
http://www.talkphotography.co.uk/forums/showthread.php?t=9766
Mr L,
Where do you buy the pack of swabs from ?
Thanks.
I can't remember but just google "sensor Swab" and any plastic ones would do.
All you need is some Pec Pads and some eclipse fluid.
wrap up the swab with the pad, careful not to touch the bit where it hits the sensor (your fingers has oils), then wrap it up. I used electrical tape. Make a bunch ready, it normally take about 3 swabs before you get it clean.
I've done a few dry cleans and they've come up perfect after 2-3 pads, so I'm yet to progress onto wet. Still scary!
It is a fairly easy thing to do, I've cleaned mine twice in the last 12 months.
Pec pads and Eclipse fluid is definately the way to go.
One thing to note is you're not actually cleaning the sensor. Your cleaning a glass filter that is in front of the sensor which is sealed behind it.
As long as you've tried blowing out most of the particles with a rocket blower type device, then anything else left behind tends to be rather sticky, such as pollen and is easily removed by the Pad and Eclipse fluid.
If you want to read up about the entire process and the various pros and cons of each type of cleaning method then take a look at this site:-
http://www.cleaningdigitalcameras.com/index.html
Not on all cameras.
On the sensors in the 5D, 5D2, 500D and 50D you're cleaning the ITO coating of the sensor itself and you need to be very careful and use Eclipse 2 fluid - which isn't the easiest stuff to work with.
Not on all cameras.
On the Canon 50D and the 5D Mk2, there is a flourine coated low pass filter in front of the sensor. The filter is made of optical glass I believe. You are therefore not touching the sensor itself which is set back behind the filter.
Yes there is a risk as in all things of damage. Providing you're careful and use the correct fluid ie eclipse fluid and CLEAN pec pads there is little risk of damage.
You can see the layout of the 50D filter in this Youtube video.
Thank you.
What camera do you have?
A Nikon D700.
I bought a wet cleaning kit maybe 6 months ago, that contained about 10 swab and holders, plus cleaning solution.
But I'd just like to buy the swabs, as I could attach them the plastic holders that I kept.
I might buy extra cleaning solution too.
