Forum Slow? or my end
I'm having same problems with everything. Can't load stuff like Google but can load OcUK. While my other half sitting next to me has no problems with any sites on his computer.
I'm on Zen.
Problems on Sky here aswell, been having problems for the past hour.
You might want to shorten down your signature a bit :)
FAQ said:
Important Sig size limits.
A signature may contain one or more images but they must fit within a box with maximum dimensions of 400 x 75 pixels (width x height) and with a maximum (combined) file size of 20KB.
Images containing mostly very large words or animated .gifs will not be permitted.
You may also add 1 consecutive lines of normal or smaller text directly above or underneath the image with no spaces inbetween image and text.
If no images are used then up to 4 consecutive lines of normal or smaller text is permitted.
Do not pad out your text lines with blanks lines. A line of text is defined as having a maximum length of 400 pixels.
Sky here playing up as well
Microsoft Windows [Version 6.1.7600]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\Darren>tracert forums.overclockers.co.uk
Tracing route to forums.overclockers.co.uk
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.1.1
2 39 ms 39 ms 37 ms cr1.wwredr.uk.easynet.net [87.87.224.182]
3 33 ms 34 ms 34 ms ip-87-87-163-161.easynet.co.uk [87.87.163.161]
4 46 ms 47 ms 47 ms te0-2-0-0.er11.thlon.ov.easynet.net [89.200.131.
85]
5 46 ms 47 ms 47 ms ge-2-1-0.mpr1.lhr2.uk.above.net [195.66.224.76]
6 46 ms 46 ms 47 ms ge-3-0-0.mpr1.lhr2.uk.above.net [64.125.28.126]
7 47 ms 47 ms 45 ms gi1.abv.tcrb.sov.serverstream.net [213.152.245.1
32]
8 * * * Request timed out.
9 * * * Request timed out.
10 * * * Request timed out.
11 *
