Conti CS3s are probably the worst wearing tyre out there. They are probably the best all-rounder performance tyre as well, though.
You can't have your cake and eat it with tyres I'm afraid.
[TW]Fox;18178490 said:Not finding the wear rate that bad?
a +1 for Kumho KU31, feel a lot better in the wet that my old bridgestone potenza.
great budget performance tyre. i had 2 x at £120 fitted.
If you just pootle around town, I can see them wearing a little better.
I did a pair down to 3mm (albeit fronts) on the VXR in about 6k miles though iirc :/
To summarise, stay well clear of the P6000. I found it average in the dry but bad in the wet.
Small bump as i've just had ContactSport 3s fitted all round. We got a blowout on one of the P6000s last night so I decided to just get it done today. Upon checking, both the backs were under 3mm so got them all done at once.
Also I drove the A38 in the pouring rain and the P6000s were all over the place in terms of grip.
Cost me £400 fitted for the CS3s.
£400 all round, fitted for CS3s? What size?
