Good point
Those are my options through elephant, alloys are obvious but what would the other mods come under?
There is stuff on there i wouldn't dream of declaring.
Engine mods and body kits that were never part of the origional model sure, but body coloured bumpers and standard alloys??
If you bought the car and were not told that it was done later how would you/they even know?
Why are the Mini options packs classed as modifications by Elephant?
They are stupid.
OP, seeing as the ST170 foglights fit in the standard car's bumper, all you need to change is the foglights to ST170 ones, change the wheels and paint all the bumpstrips. Hardly a massive list of mods but it does make a positive difference.
Ignorance is not a valid excuse.
It wouldn't surprise me if in man cases insurance worked out cheaper (Modified example of lower speced car vs standard example of higher speced car).
A modification is any change to the car away from the manufacturer's standard specification including optional extras, such as alloy wheels, body styling kits and exhaust/carburettor upgrades.
my opinion is that having a car that looks like a few models higher is a pointless idea.
sure if they are interior upgrades, say like more comfortable seats/ uprated sound system, stuff a standard model would lack then fair enough. but making a slow car look like a fast car is something i just cant understand.
Yes, because they are changes to the base spec. They are options and you would hate to not have them accounted for in a payout etc
Are you or are you not the owner of a very expensive water cooled PC? A lot of car modders would never "get" that
Don't get me wrong, OEM (or OEM+) all the way. Life is too short for silly body kits and uncomfortable suspension
yea but dont his pc run colder for that? sticking a body kit on dont really do much does it
You don't get my point do you?
On an SE spec car, are the alloys optional? Body coloured bumpers? Parking sensors? I think in my case the wheels and bumpers are standard, parking sensors maybe not.
Another point is if they want a list of options they should ask when they are talking to you on the phone. I was only asked about modifications.
Neither does glass windows or neons in cases, or the colour of the case or.....
Visual things make people happy just like performance enhancing ones![]()
But how are some of them modifications?
