+1 for the H70 and Viper Fans using the PWM.
Idles at 36 and is pretty much silent. Seems to top out about 73 running Prime95 for 4 hours.
Thanks
Chris
are you running your fans as intake or exhaust ?
Thanks
Chris
would the h70 fit in an antec 300?
I was considering both the H50 and H70 but decided on the Thermalright HR-02 (thanks to cmndr_andi). It's a passive cooler and if you need better cooling for extreme overclocks you can stick a fan on it. Being just a chunk of metal nothing can really go wrong with it!![]()
Saying that, I managed to cool my 920 passively at 4GHz.
What cooling setup was that?
