Another Sandy Bridge 'Help Me' Thread (with pics)
If you are ordering this week you could get MSI mobo instead and get the VAT rebate which will give you back £23ish. Also there is some Geil 8GB ram set on special until Wednesday.
Oh and don't forget the novatrise code for some more savings:).
Looks good - you've considered all the stuff - don't forget your OS :)
Does anyone know if that cooler comes with thermal paste applied?
If not, get some Silver 5.
looks good to me.
glad you kept the solid state drive, i have just upgraded to the vertex2e and will never look back
hope the build goes well
Ha, I just started a thread about Windows 7, can't find it cheap anywhere! Which is hardly stating the obvious but maaaan, is it annoying. All I can find are upgrade packages. I'm a student but the discount doesn't help me as I can find the full thing (which I assume I need?)
Also, what is the Novatrise code?
EDIT: Cheers, coleman.
According to this review an overclocked 570 beats an overclocked 6970 and is also slightly quieter so if it were me I would get a 570. Having said that being able to unlock a 6950 to a 6970 is very tempting. I do prefer nvidia so i'm slightly bias tho.
Edit: I hear SSD's are a great upgrade so I would get one if I had the cash
if he was saying 570 or 6970 and was playing at standard rez then yes, but he wants cheap as possible and the 6950 with the unlock is fantastic value atm
Asus Xonar instead of the Creative Sound Blaster as already mentioned is the only noticable swap other than the cooler.
As for the SSD.. Only people who have never used an SSD would try to convince you against getting one. An SSD is a must for a new build of that value! You will not regret it.
An SSD is simply the best upgrade available and when building from scratch on your budget is a MUST.
