Am I going to be OK using standard Corsair XMS stuff then?
OcUK shows the voltage for this memory as 1.6-1.7v but I've seen it listed as 1.65v elsewhere. 1.5v rated stuff seems to cost a load more.
This thread is getting linked from various places, but is there actually other reports of this? Only thread I can find on "2500k died" or variations is this one.
Also "was running a Vcore within the spec, well within the spec at 4.8ghz" sounds a bit clandestine. What vCore were you actually running?
Hi there
I've spoke to Intel this morning and got the following answers from them:-
1. Anything over 1.40v on air is risky, upto 1.50v on water should be OK but risky.
2. Anything over 1.50v on memory is not recommended but should not kill a CPU.
3. Clocking on BCLK is highly un-recommended due to onboard graphics.
So the biggest factory they say is vcore, pushing above 1.40v is a risk, therefor I'd say don't go beyond 1.35v. BCLK clocking is a no no for sure.
I've asked for documents regarding 1.50v as motherboards manufacturers seem to think 1.65v is the safe limit, though Intel are saying 1.50v is more advisable.
I am going to update all our CPU descriptions with this information.
Anyone with 1.6-1.7v memory should run the memory at 1.50v as in theory it will run fine at those voltage as all memory manufacturers are now on new IC's.
Hi there
In our own testing we have found the only thing killing the CPU's is core voltage. We've found setting memory voltage at 1.65v seems to be doing no harm, but were now gonna setup 3 rigs, one with 1.45v core volts, one with BCLK overclocking and one with 1.65 memory clock to see which one if any dies first. We shall do this on 2500k chips.
Hi there
Thanks for that Gibbo - does clarify things.
Might be worth putting a note against all your 1.6v+ memory saying it's not compatibly with SB at that voltage.
I'm now trying to decide whether to leave my order for the XMS3 stuff and just run it at 1.5v/1333Mhz or splash out on an 8GB 1.5v/1600Mhz kit.
Also, given the comment on the Corsair site I mentioned above, I've posted on their forums asking for their take on this issue.
