The Eunos is a better donor as many of them had an LSD which the UK car's didn't.
Mines a Eunos 1.8IS, deffo has a Torsen under its bum
Loving the team name! Will you be having a decal to that effect on the car?
Mines a Eunos 1.8IS, deffo has a Torsen under its bum![]()
If anyone has a car trailer going I'd welcome a discussion.
The cars are pretty controlled in terms of what you can do but effectively its new everything, brakes, lines, exhausts, shocks, bushes, engine blue print, rads, cage, fire control and to make it a race car with donor car you are probably in the region of £6K - £7K all in, though corners can be cut if you self build, which I am not. In motorsport terms it's peanuts but I will share build logs and all sorts of other stuff as we go.
Can i have a big sign on both sides?
How many cars are their going to be?You provide the trailer you can have what you want...........on the trailer
In terms of sponsors we are seriously trying to get a full team sponsor so we can brand all the cars into one team colour, Gulf or Martini would be full of win, though perhaps over ambitious!![]()
Woah, Both sides Mark? I know you have some dough but come on...![]()
Hi Housey,
Good on you for getting stuck in.
I didn't realise it was quite so much to build a car for the Mx-5 championships.
Did you consider racing anything else instead? The same sort of money would buy a decent single seater like a pre-90 formula ford 1600. Much quicker, easier to fix, races nearly every weekend of the year and even a dedicated championship starting up for them this year.
I understand though that a big part of the appeal may be the build itself and doing it with your mates. I have heard good things about the mx-5 racing.
I've taken the single seater route myself hence the question
Do you already have a race license or are you in the process of taking your ARDS etc at the moment?
Re: car trailer, what are your requirements and where are you based?
How many cars are their going to be?![]()
We plan to have 6 cars, though not at every event. There will also be a rental model for those with appropriate skills, accreditations and experience. I shall put up some thoughts on this as we progress as I would like an OCUK driver line up at one event in the future...
