Hi there
Anyway I promised you guys two bundles first thing, I've hit your price targets making us the cheapest in the UK, check them out:-
OcUK Motherboard Bundle - Intel Core i5 2500K & Asus P8P67 Intel P67 Mainboard @ £299.98 inc VAT
Our motherboard bundles are designed using all compatible components to prevent you our customers the confusion of working out what workds together.
The main specifications of this bundle are: -
- Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor
- Asus P8P67 Intel P67 (Socket 1155) DDR3 Motherboard - (Sandybridge)
Every bundle comes with a processor and heatsink/fan, all is designed to work together in harmony, all you need to do is the simple process of inserting the CPU, fitting the cooler and installing your chosen memory.
Technical Specification of components:-
Processor:-
- No. of Cores 4
- Supports Virtualisation Yes (VT-x)
- Architecture Features 32nm
- Cache 6Mb
- Clockspeed 3.30Ghz (3.70GHz with TURBO)
- Manufacturer Intel
- Intel reference cooler
- Unlocked Multiplier
Motherboard: Asus P8P67 Intel P67 Mainboard
Key specification:
- ATX Form Factor
- LGA1155 socket for Intel® 2nd Generation Core™ i7/ Core™ i5/ Core™ i3 Processors
- Intel® P67 Express Chipset
- PCI-E x 16 Single x16 or x8x8x4
- Supports ATI® Quad-GPU CrossFireX™ Technology
- 4 x DDR3, up to 32.0GB
- 8-CH HD audio
- Gigabit LAN controller
- 2 x USB 3.0 ports at back panel (blue)
- 2 x USB 3.0 ports at mid-board for front panel support
- 12 x USB 2.0 ports (6 ports at mid-board, 6 ports at back panel)
- 2 x SATA 6.0 Gb/s ports (grey)
- 2 x SATA 6.0 Gb/s ports (navy blue)
- 4 x SATA 3.0 Gb/s ports (blue)
- Bluetooth v2.1 + EDR
- 2 x IEEE 1394a ports
In The Box:
- 1 x 2-port USB and eSATA module
- 2 x Serial ATA 6.0Gb/s cables
- 2 x Serial ATA 3.0Gb/s cables
- 2 in 1 Q-connector
- User's manual
- Warranty: 3 Year
See related products for Sandybridge compatible memory and coolers.
Only £299.98 inc VAT.
ORDER NOW
OcUK Motherboard Bundle - Intel Core i7 2600K & Asus P8P67 Pro Intel P67 Mainboard @ £399.98 inc VAT
- Intel Core i7-2600K 3.40GHz (Sandybridge) Socket LGA1155 Processor
Processor:-
- No. of Cores 4 (8 with hyperthreading)
- Cache 8Mb
- Clockspeed 3.40Ghz (3.80GHz with TURBO)
Motherboard: Asus P8P67 Pro Intel P67 Mainboard
Key specification:
- ATX Form Factor
- PCI-E x 16 single x16 or x8x8x4
- Supports NVIDIA® Quad-GPU SLI™ Technology
- 8-CH HD audio
In The Box:
- 4 x Serial ATA 6.0Gb/s cables
- 1 x ASUS SLI bridge connector
- 1 x ASUS USB 3.0 Bracket
- ASUS Q-Shield
- User's manual
- Warranty: 3 Year
Only £399.98 inc VAT.
ORDER NOW
Is this the actions of someone who has no respect for their forum members?
Processor:-
- No. of Cores 4
- Cache 6Mb
Key specification:
- ATX Form Factor
- 8-CH HD audio
In The Box:
- User's manual
- Warranty: 3 Year
ORDER NOW
Processor:-
- Cache 8Mb
Key specification:
- ATX Form Factor
- 8-CH HD audio
In The Box:
- ASUS Q-Shield
- User's manual
- Warranty: 3 Year
ORDER NOW
