If you want to play 5760x1200 with 16xAA/AF then you will most likely run out of frame buffer on the 570's, but neither 6900 nor 570 configs will be playable due to GPU limitations. 4x AA will be fine for both within most games but adding AA and details does not only affect frame buffer. GPU power is often more important.5760x1200 resolution needs vram.
2x6950 flashed to 6970 now is the best choice for you.
Leave nvidia gtx570 sli back and go aheadl
Eyfinity is a good AMD selling point for single card solutions because NVidia cards only support two outputs. However, NVidia dual card SLI solutions support tripple/quad screens, and in this scenario the benifits of Eyefinity are largely pointless (unless you need to connect more than 4 monitors).555BUK, why do u say Eyefinity is not really relevant for dual card solutions? It's highly relevant to triple 24"s.
I'll be receiving the rest of my 3 monitor set-up (3x 23" 1920x1080 Dell screens) on Thursday, so if you like I'll run a series of games with various AA levels on Friday/Saturday, measuring VRAM usage and seeing what kind of frame rates I'm getting. If the VRAM levels exceed 1280MB regularly than your choice should be made for you...
I'd say 2x GTX 570's. Ultimately faster than 6950/6970 and the better cooler and quieter running can be important for dual card setup. Overclocked 570's can easily exceed GTX 580 performance, whereas 6950's/6970's cannot. Proper 3DVision and Physx may or may not be important for you as well.
Eyefinity is not really relevant for dual card solutions unless you plan on connecting more than 4 monitors (NVidia SLI supports 4).
There are not that many games which fully support 3x monitor setup and those that I can think of do not require lots of VRAM anyway. The two best multi monitor titles (Dirt 2 and HAWX 2) also favour NVidia cards.
Please enlighten me regarding which points are incorrect? I will sumarise them for you.This is such a ridiculous amount of misinformation.
