Is there any disadvantage of doing a foundation degree instead of a normal degree, apart from the extra year?
[TW]Fox;18201804 said:Yes, it's a foundation degree which is nothing like as good as a normal degree. You only do a foundation degree if you are not qualified enough to gain entry onto a normal degree programme.
Not exactly true that is it, considering foundation degree's are only named that way due to a pre-certificate stage being added before the degree starts, which is usually carried out at the uni itself. How is getting a first in a foundation degree 4 year course where you sit through all of the same classes as someone doing a 3 year bsc course in the same subject any different?
You're thinking of a Foundation Certificate - a Foundation Degree (in my case anyway) is essentially the first two years of a degree course, requiring only 1 extra year to top up to a full degree (BSc in my case).
[TW]Fox;18201976 said:I know exactly what a foundation degree is!
I'm saying foundation degrees are for people without the qualifications to go straight onto an undergrad degree. Which bit of that isnt true?
ie there is simply no way you'd choose to do one unless you had to, which makes the question rather strange - as you dont have a choice between a normal degree and a foundation degree, if you can do a normal degree you dont even consider the foundation!
I'm not disputing that, just the statement that a Foundation Degree is "nothing like as good" as a normal degree. Its the same thing, same material, albeit a shorter course of study.
The Foundation Degree is a vocational qualification introduced by the government of the United Kingdom in September 2001, which is available in England, Wales and Northern Ireland. It is similar in level to the associate's degree awarded in the United States, and in the United Kingdom sits on the same level as the Higher National Diploma (HND) and Certificate[1] but below the Bachelor of Science/Bachelor of Arts/Bachelor of Laws level of education. Courses are typically two years long and are offered both by universities and colleges of higher education.
Foundation degrees are intended to give a basic knowledge in a subject to enable the holder to go on to employment or further study in that field. They were designed in partnership with employers and further education colleges (FECs).
[TW]Fox;18202010 said:The other disadvantage is that it wont look as good on your CV.
If two people send in a CV, one with just a degree, the other with the same degree but a foundation year, it tells the employer than one of the people didnt have the ability to go straight onto a degree. This is a disadvantage - you will doubtless now cry this isnt the case but it is, just look at the number of employers who have UCAS points as acceptance criteria - people DO look at what you did before your degree.
[TW]Fox;18202033 said:No, it's not the same thing at all. Only if you choose to then go on and top it up to a full degree is it the same thing. A foundation degree on its own is not the same as a full degree at all.
I hate to use Wikipedia as a source but it backs up what I am saying:
Either way, I'd still consider my course a degree course, as (apart from the title), I'm automatically offered the opportunity to go on to complete the full degree at Plymouth uni.
That source only mentions the actual precertificate stage of the degree though, as the rest is the bsc anyway. No full degree course is only 2 years long, especially with a foundation year added into it.
