[TW]Fox;18202070 said:Thats the point - a foundation degree is 2 years long. Then you can use it to go onto a normal degree, from which you are usually exempt the first year and go straight into 2nd year..
The daft thing is, even that is based on incorrect information. My local university has 1 year foundation degree's which are indeed at the HND level of education. They are directly linked to the BSC's in their respected subjects and automatically gain admission to the "proper" degree as well, so no more going back to UCAS etc.
I do see what you mean about putting it on the CV but even so, you could probably get away with just putting the actual course down with your grade anyway.
