Just got a free xbox :)
Chances are whoever owned it thought it was properly knackered with the rrod and threw it out.
what did you replace the old xclamps with? i tried fixing friends and couldn't get it to stay fixed for long
If you remove the clamps and the threaded barb bits on the bottom of the heatsinks you can just put screws through the mainbard into the heatsink and it will fit a lot more tightly and securely. You can get kits of ebay for this purpose that have all the screws and washer in that you need if you dont have any such things lying around like i luckily did.
So you just took it without a thought for the owner? You didn't even spend 30 seconds trying to locate them? I bet you even jogged home. Nice. How's it feel to be a thief?
The guy probably popped back into his house for keys or something. :p
