I prefer to have more intake fans on my case than exhausts, it came with 2 x 140mm as standard, but i added another 120mm into the 3 remaining 5.25 bays.
Yep, dust has never been a problem thankfully, all intake fans are filtered and it literally takes seconds to access the filters, simply pull the entire front panel of the case.I agree. You end up with higher pressure inside the case which stops dust getting sucked through any cracks/gaps. As long as the intakes are filtered, you end up with much cleaner pc.
