Take it to a ford dealer, get it serviced and see if they spot it. If they don't you can use that in your defense![]()
Good Plan
of course theres something to loose.
If you go to another dealer and ask them to service and act all surprised at the fault they find Ford are going to tear you a new one - because it looks like exactly what you're trying to do - con them.
Is the gearbox seviced at a 37.5k service interval?Where would you draw the line for being out of warranty? 2k over, 5k, 20k more?
Mate were talking about a gearbox which i suspect isnt included in any services up untill now ... Then we get onto a gearbox failing when its only done 39000 miles when its on an 09 plate.
To be honest im not really bothered, just trying to help someone out in my company![]()
Gearbox oil level is checked on every service and that is all the excuse any main dealer will need to invalidate the warranty, the AA are not covering a head gasket on a astra we have because it was serviced a month too late.
What exactly is wrong with the gearbox?
On a side note, we have a 2005 Focus we bought last year and my girlfriend made me get the 2 years warranty :/ Is there anywhere written down clearly that says we must have the car serviced next at x miles / x years to make sure the warranty isn't invalidated? All i got from them was a one sheet piece of paper saying what warranty i'd actually bought.
they are not going to "tear you a new one".... you are the customer... there is nothing wrong with getting a car serviced with a known issue..
if the don't find the fault then you can say to Ford CS "I had it serviced WITH the fault and they never noticed, so how would they have picked up the fault 1500 miles ago"
