Use blob in the middle method, spreading thin a thin layer can lead to an uneven contact.
I would replace the TIM and re-apply the heatsink.
Did you know that the new top of the range paste is the IC Diamond which is on This Week Only![]()
But what tempreature difference does it make? I used to use Artic silver but now I just get mx5 because its cheaper. Whats the difference between mx5 and mx6 btw?
