Can I buy a Blackberry 9800 (torch) to replace my 9700 (bold) and just swap the sim and memory card over or is it not that simple? and if not what would I need to do? thank you.
Yep you can as long as the handset is unlocked...if it is then you can just swap sims as you like although you might need to tell your network so that they can enable the blackberry data plan onto the new handset.
Officially through your carrier it costs about 15-19 depending on who it is, and unofficially through random shops cost from 5 - 10. If done through the carrier you also need to have been with them for a while.
