i3 540 V's q6600
22 Oct 2010
Pontefract
simple question i3 540 @ 3.7 (OC is estimate) V's q6600 G0 @ 3.1 witch is best.
Not witch is best for gaming or video or web walking witch is best all in.
The Q6600 with a decent overclock. More and more games are making use of more than 2 cores now, i personally have an i3 overclocked to 4Ghz, but that was a completely new build.
Ive come from a OCd Q6600 to an i3 @4.4ghz and tbh im loving it, much faster, Better for F@H. Loads Cooler too, altho i am watercooled.
I dont think you will be disapointed :D
You can overclock Q6600 more to 3.4Ghz if you want:). That will give you 1Ghz overclock which is about 42% extra performance from Q6600 and this is brilliant:).
i3 will be faster in two threaded applications. However it will struggle in games that make use of 3-4 threads against Q6600 ;).
Your wrong there.
Do a search and check comparisons.
Though if you get a good Q6600 that overclocks well then things become different.
My motherboard a limiting my q6600 OC to 3.1 stable. witch is way i was asking about the i3 because a Good 775 board and cooler to OC more like 3.8 would cost nearly as mush as a low cost i3 package would.
Intel Core i3 540
Corsair XMS3 4GB
Gigabyte GA-H55M-UD2H
total with postage = 195.77
To OC my Q6600 G0 better
Asus P5Q Deluxe
Thermaltake Frio
total with postage = 167.84
derrrr i am not factoring in the money from selling my Q6600 and Xms2 derrrr i think i will look at some i5
i3 will beat the Q6600 in everything.
I went from a Q6600 @ 3.466 to an i3 @ 4.0 and the i3 had better fps in every game I tried.
Plus they run considerably cooler, and use far less power.
You can overclock Q6600 more to 3.4Ghz if you want:)..
OMG. i wish people would stop giving crap advice. not every chip is the same! you cant just expect 100% of chips to overclock to some set standard.
but this is intresting though, i didnt realise that the i3 beats the q6600 on most stuff and selling old stuff can offset the cost quite a bit!
I have a Q6600 that I run at 3.8Ghz stabily with very good air cooling but *very* few will do this. The average I would expect is ~3.4Ghz with decent voltages/temps.
4Ghz+ on an i3 should be faster than a 3.4Ghz Q6600 in most things that you seem to do but optimised SMP stuff I would take the quad core.
It's a shame that you can't access the members market yet to pick up a good second hand board P35/P45 board for around £40 as that would get the most out of your Q6600.
i had a MSI P35 platinum witch gave 3.6 stable but i distroyed the board with a bad bios flash i did fix it but it never been the same witch is way i now a low cost board witch is crap
