5850 1GB is probably the nearest ATI card in terms of performance.
Also there is an SLI hack for crossfire boards, I don't know the full details but I'm pretty sure it's something like a special driver. Might be worth reading up on.![]()
Nope. 5830 is slower than even the GTX460 768MB, whereas the 6850 is on par with GTX460 1GB; the 6870 on the other hand sits between 5850 and 5870 speed. But one thing to note is that the crossfire scalling is better on the 68xx than the 58xx.isn't the 6850 basically a refreshed 5830 card which was slightly lower than a 460GTX?
6870 is basically a refreshed 5850?
the card numbering is a bit sneaky by ATI imo....makes you think you get a next gen similar card but it's actually a level down on the previous gen
