WEEKEND ONLY DEALS - ROUND 5 MEMORY!!!!
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Some stunning deals for the WEEKEND ONLY on memory and lots of Sandybridge approved memory kits as well:-
Corsair XMS3 6GB (3x2GB) DDR3 PC3-16000C9 2000MHz Triple Channel Kit (CMX6GX3M3B2000C9) @ £113.99 inc VAT
Corsair’s mainstream memory solution for the Intel Core i7 triple channel memory processors and platform. The XMS3 family is Corsair’s mainstream line of performance DDR3 memory. These modules allow users to experience outstanding memory performance and stability. Available in Corsair’s new XMS heat spreaders, each module is built using carefully selected RAMs.
- Three matched 2GB modules for use in high performance Intel Core i7 Triple Channel systems
- Outrageously fast 2000MHz performance using 6GB of memory
- Ultra-low 9-10-9-27 latency
- Density: 6GB (3x2GB Module)
- Speed: 2000MHz
- Timing: 9-10-9-27
- Pin Voltage: 1.65V
Was [£124.99] Inc. VAT
Only £113.99 inc VAT.
ORDER NOW
GeIL 12GB (3x4GB) DDR3 PC3-12800C9 1600MHz VALUE PLUS Triple Channel (GVP312GB1600C9TC) @ £119.99 inc VAT
GeIL announces the launch of the all new DDR3 Value PLUS & Ultra PLUS Series to be added to GeILs’ high performance memory line of products. The Value PLUS & Ultra PLUS are equipped with the latest PLUS Edition memory heat-spreader designed with heat-sink surface and extended height for maximum cooling efficiency. The Ultra PLUS line of memory will be carrying over-clocking performance while the Value PLUS line has the more stability-oriented specifications. As GeILs’ quality standard, both series will be enhanced with DBT – Die-hard Burn-in Technology for the highest quality assurance.
- PC3-12800 1600MHz CAS 9-9-9-28
- 240pin, Non-ECC, Un-buffered DDR3 DIMM
- Aluminum Heat-spreader
- 6 Layers Ultra Low Noises Shielded PCB
- 1.5V-1.6V Power Supply
- Lifetime Warranty
- DBT - Die hard burn-in technology (Improved reliability)
Was [£139.99] Inc. VAT
Only £119.99 inc VAT.
ORDER NOW
GeIL 6GB (3x2GB) DDR3 PC3-12800C9 1600MHz VALUE PLUS Triple Channel (GVP36GB1600C9TC) @ £51.98 inc VAT
- Lifetime Warranty
Was [£66.99] Inc. VAT
Only £51.98 inc VAT.
ORDER NOW
G.Skill RipJawX 4GB (2x2GB) DDR3 PC3-17000C9 2133MHz Dual Channel Kit (F3-17000CL9D-4GBXMD) @ £99.98 inc VAT
G.Skill has announced the development of its brand new RipjawsX series memory modules, designed specifically for Intel Sandy Bridge LGA1155 processors, and H67 and P67 motherboard platforms. The new RipjawsX series consists of a complete range of memory solution, from DDR3 1,333MHz, 1,600MHz, 1,866MHz, 2,133MHz, 2,200MHz to 2,300MHz. Combined with the Intel’s highly anticipated Sandy Bridge platform, G.Skill RipjawsX series memory kits deliver more bandwidth and performance than ever.
Building on the strong success of the first generation Ripjaws brand in performance memory kits, every single RipjawsX memory kit is hand-tested on an Intel Sandy Bridge platform in accordance with G.Skill's strict internal testing procedure, to ensure the best in class performance, compatibility and reliability across a range of popular motherboards. It is the perfect memory solution for PC gamers, performance workstations, enthusiast power users and anyone who loves the cutting-edge of technology!The following list shows the detail specifications of G.Skill RipjawsX family.
Model Name: F3-17000CL9D-4GBXMD
Main Board: INTEL
System: DESKTOP
System Type: DDR3
M/B Chipset: INTEL P67
CAS Latency: 9-10-9-28 2N (Capable of 6-8-6-24-2N at 1600MHz)
Capacity: 4GB (2GBx2)
Speed: DDR3-2133 (PC3-17000)
Test Voltage: 1.5V
Registered/Unbuffered: Unbuffered
Error Checking: Non-ECC
Type: 240-pin DIMM
Master Pack Dimension: 8.5 x 5.5 x 0.62 In (L x W x H)
Master Pack Weight: 0.26 lbs
Black PCB
Warranty: Lifetime
Was [£109.99] Inc. VAT
Only £99.98 inc VAT.
ORDER NOW
G.Skill RipJawX 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (F3-12800CL9D-4GBXL) @ £41.99 inc VAT
Model Name: F3-12800CL9D-4GBXL
Main Board: INTEL
System: DESKTOP
System Type: DDR3
CAS Latency: 9-9-9-24 2N
Speed: DDR3-1600 (PC3-12800)
Test Voltage: 1.5V
Type: 240-pin DIMM
Black PCB
Warranty: Lifetime
Was [£49.99] Inc. VAT
Only £41.99 inc VAT.
ORDER NOW
G.Skill RipJawX 4GB (2x2GB) DDR3 PC3-12800C6 1600MHz Dual Channel Kit (F3-12800CL6D-4GBXH) @ £67.99 inc VAT
Model Name: F3-12800CL6D-4GBXH
Main Board: INTEL
System: DESKTOP
System Type: DDR3
CAS Latency: 6-8-6-24 2N (Capable of 2133MHz at 9-10-9-28-2N)
Test Voltage: 1.5V
Type: 240-pin DIMM
Black PCB
Warranty: Lifetime
Was [£74.99] Inc. VAT
Only £67.99 inc VAT.
ORDER NOW
GeIL 4GB (2x2GB) DDR2 PC2-6400C4 800MHz Ultra Low Latency Dual Channel (GX24GB6400C4UDC) @ £54.98 inc VAT
GeIL is proud to announced DDR2 800MHz, PC6400 800MHz supports CAS 4-4-4-12 with 2GB and 4GB Dual Channel Kits. These Ultra modules are hand picked for maximum FSB overclocking potential.
- PC6400 800MHz CAS 4-4-4-12
- 64x8 DDR2 BGA Chips
- 240pin, Non-ECC, Un-buffered DDR2 SDRAM DIMM
- Lifetime Warranty
- 1.9V-2.3V Power Supply
Was [£59.99] Inc. VAT
Only £54.98 inc VAT.
ORDER NOW
These are stunning memory deals and remember loyal forum members get FREE SHIPPING too. :)
when it comes to memory, does the new i5 Sandybrige need different DDR3 sticks ? lower voltage etc?
You can use old DDR3 but don't run it above 1.60v and aim ideally for 1.5v.
Corsair XMS3, Vengeance, GeIL and G.Skill sold by OcUK is all Sandybridge compatible. :)
Damn the Gskill Model Name: F3-12800CL6D-4GBXH looks tempting now.
I ordered 8g of the Geil as was cheap last night :( , along with a UD4 and SB 2500k.
What would be better for gaming then ?
4g of Gskill or 8g of the Geil value
