Why Are Some People So Dumb?
Status
Not open for further replies.
Why start a thread with an insult in the title? It's almost as if you're trying to provoke a response.
Oh, wait, I get it :p
If those two guys bought their SandyBridge chip from OcUK, they can now officially consider their warranty voided and OcUK can refuse to honour, since they are kind enough to provide evidences by posting a screenshot of CPU-Z of using over 1.38v lol :D
Not really http://www.overclockers.co.uk/showproduct.php?prodid=CP-358-IN&groupid=701&catid=6&subcat=1859
***OVERCLOCKING GUIDELINES***
- Do not exceed 1.35-1.38v core voltage, doing so could limit lifespan of the CPU
- Do not overclock with BCLK, again doing so could limit lifespan of the CPU
- Recommended memory voltage is 1.50v, so make sure to run your memory at 1.50v, higher could limit lifespan of the CPU
- These recommendations come from OcUK and Intel, your warranty is un-affected but we highly recommend you adhere to the above to make sure your CPU lifespan is un-affected
- All Sandybridge CPU's worldwide should be run at the above or lower voltages, no higher!
does seem like a strange thing for them to write but i guess they cant give overclocking advice on the one hand and then say that it voids the warranty on the other.
My overclocking is so timid if i got to increase voltages then i say no thats as far as ill go, hence my chip sitting at 3.7GHz. Thats a whole 300MHz difference:p:D
Oh so even though it's the users fault for exceeding the safe voltages of a 'weak' chip, the warranty still covers it? In that case tbh I'd probably experiment with a lot less caution too.
This is overclockers... what do you expect?!
I find it amazing hardware can be pushed so far from its stock setting and do admire those who are willing to see how far it can go, often to the benefit of others. I personally wouldn't go above recommendations purely as I'm not willing to risk it, at the cost of replacing etc.
If people
Status
