- 25 Nov 2002
- Somerset
I tried to go higher and it will not boot. I am surprised you are getting temps up to 65C after hours running Prime 95 with a Artic Freezer 7 Pro rev 2. I am getting 71C max @ 1.280v with a Akasa Venom a better CPU cooler (in theory). This would suggest you are running with a lower voltage (unless my installation of the Venom is crap but I do not think so, its 17C cooler then stock)
I just wanted to say that the Sandy bridge CPU and P67 really do work in a different way to anything we have seen in a desktop before... it's much more like a laptop.
What i think is catching many people out is the fact that when speedstep / turbo cuts in and out the voltage changes too.
I can only talk about the Asus P8P67 Pro as thats the only board i have, but what happens is...
If the CPU Vcore voltage is set to Auto in the Bios then the voltage in windows will change massivly at stock speed from something like 0.890v to 1.256v. This will scale up in conjunction with the Multiplyer increasing and the amount of time load remains on the CPU.
If the voltage is manually set in the Bios by selecting manual and then entering a CPU voltage... say 1.20v then you will have 1.20v regardless of the speedstep / turbo multiplyer setting. Meaning at 1600MHz 100x16 (when idle) you will have a vcore of 1.20v and at full load say 3300MHz 100x33 (2500k at stock) you will also have 1.20v vcore. the result oif this is that your idle temps will be higher and your full load voltage is lower than on auto (so you may become unstable).
There are also settings in the bios that will cause vcore to rise massivly if the CPU is demanding more current. I have seen mine, while set at stock vcore rise to 1.35v when running prime, but I have adjusted some of the Power functions in the bios.
You also need to understand that other things affect the CPU temp. PLL voltage and also the memory controller, so Ram voltage and speed.
In summary... working out what is going on with your voltages / temps on Sandy bridge is much more complex than before.
Another quick note. Asus Bios 405 shows much lower temps than the latest ones... I trust the later ones myself.
