tbh for a budget install i dont think he will need soundproofing, not worth it for 200wrms
If you want to soundproof on the cheap get a few rolls of flashing tape from B&Q @ ~£7 a roll.![]()
i know this is gonna sound silly, but id say do the big3 aswell, being as the amp alone can draw 75amps and a yaris alternator is rated for 80amps. (dont want to flatten your battery)
big 3 means getting some 4 guage amp wire (0or1 is better but i think 4 will do for your size) and replacing the alternator to battery+, battery - to body, and engine to body with it.
This is the best I've seen so far...Are there any good sites out there with guides on ICE installation?
