Software Firewall
2 May 2004
Hi,
I've been using Comodo for years as it lets me know when anything is going in/out and asks me what I'd like to do regardless of what it is.
Is this still the best firewall around for that functionality? Is there anything better these days?
Yes I know the built in firewall is good enough etc etc.
Running Windows 7 x64
Thanks.
With regard to the general question of "is there anything better these days?" then I share the following opinion:
Why do you want to restrict outbound traffic? It provides very little security, if a piece of malware is on your machine and able to attempt outbound connections you're already hosed. If you allowed the malware to install itself with admin privileges the malware can reconfigure the firewall and go to town. If you were smart and running with limited privileges when the malware installed itself it can scan the firewall rules to see what is allowed, and piggy back on one of those applications. For example, you'd want to allow your browser to open outbound connections, right? Its not very hard to write malware that will use the default webb browser to upload stuff.
I am not saying that outbound filtering provides zero security, only that its provides very little. In my opinion its not worth the hassle, you would be better off investing the effort in customizing outbound rules into more effective countermeasures like figuring out how to get all of your programs to run without admin privileges, installing patches, or updating antivirus and antispam software.
I had to borrow this from the technet forum as I don't think I could be quite as concise at almost three a.m.
I agree with ncjok.
Router + Patched Windows + Patched software + MSSE + Windows Firewall + common sense = pwnsauce.
I use:
Windows Firewall + up-to-date Windows + NOD32 Anti-virus + broadband gateway router + my head (eg. mouseover links before clicking them)
Windows firewall does a pretty good job of blocking incoming malicious connections ..... 99% of trojans, etc are the faultof a user as it occurs if you're browsing dodgy websites or opening dodgy attachments.
peerblock + pfsense hardware firewall.
peerblock is not a firewall it is a blocklist software. So if a ip is not in your list then it won't be blocked.
I get so annoyed with software firewalls popping up every time i initiate a new connection and find that it does not realy help that much. because most of the time people just enable the connection anyway...
I agree with ncjok.
It's not the security I'm wanting, I just want to control what goes out, and would like to know what actually does go out.
Security isn't an issue at all, I'm well aware of all that and have adequate defences in place, but I still want to control what goes out of my computer.
Zone alarm seems to be very popular although I must agree with the points made in the post above.
I've not heard much good at all from Zone Alarm users - apparently it interferes. A lot.
Craig
Although I agree with the statement from the technet forum to an extent, I also believe that filtering outbound traffic does provide a fair amount of security (obviously not as much as inbound) but it can alert you to things. The comments made are very arguable.
For inbound use your router. For outbound Vista/Windows 7 + Windows 7 Firewall Control will give you pop-up notifications to block outbound connections. It uses the built-in firewall (Windows Filtering Platform) from Vista/W7 so uses a tiny amount of memory (~3MB).
Their site looks rubbish, but it works quite well.
Does Windows firewall incorporate program monitoring? I talking about things like, program component monitoring, program launch/executing etc. Where that, if the program (say IE) is allowed to access the internet, if the executable is changed (update applied or malware injected) the firewall can detect a change and asks for permission again?
Out of curiosity could you elaborate on why you require this functionality?
Do you have a couple of examples of things you've blocked that were surreptitiously attempting to make outgoing connections? Things which you considered a security breach, perhaps, as opposed to a simple nuisance.
Are you running Windows 7? If so, you'll have awesome control over outbound traffic.
Yup, and I know. Still doesn't do what I want it to though :)
I'll check it out, thanks.
I have my reasons for wanting to know if a program is connecting to the internet or not. Obviously I don't need to worry about the usuals (Outlook, Firefox, etc etc.), but I use a lot more than that.
Craig.
