- 12 Jan 2011
Hi All
I need suggestion to decide whether should I buy 23 / 24 inch monitor
Recently upgrade my PC and need new monitor . Rig spec: i7-950, Radeon 6870. Atm, I'm using 16' wide monitor
Mainly use for gaming, surfing, bit of Photoshop and office
I have couple Q's on before decide which monitor should I buy
-Should I get 23 or 24 inch? Consider or 24 has 16:10 aspect ratio and 1920x1200 res, is that would make any significant diff compare with 23 inch which have 16:9 ratio and 1920x1080 res?
-Both are IPS panel, however some said that 23u11 is E-IPS and 24u10 is S-IPS. is it worth of getting S-IPS over E-IPS consider big gap of price between u2311 and u2410?
Any comments and suggestion would greatly appreciate!! Sorry if its like noob q's
Also if there others monitor suggestion are more than welcome
Regards
Regards
