Very nice m8, theres lots of info on the net, which way have you got the Apaches > push or pull. If push, try pull you may get a couple of degree's cooler, basicly my Rad set up was push / pull. So l did a little bit of research and found that 3 fans in pull were better it knocked off 2'c from my CPU 4.2GHz and 1'c off my GPU 470 850:1700:2000 + the fans peaked at lower rpm so PC was even quiter.
Go to skinnee labs, l think your Rad has been reviewd there, you will probably find out the best way to have your fans push or pull!
Link - http://skinneelabs.com/
might just get the XSPC or Koolannce cooler at this rate
