- 20 Jul 2009
- Midlands
Today Only we have 50 units of the Asus Geforce GTX 460 Direct CU TOP 768MB Graphics card. At only £113.99 inc VAT and with Free shipping to loyal forum members the Asus GTX 460 is an absolute steal delivering blistering performance perfect for the best in game experience.
We also have 100 units of GeILs highly popular GeIL PC12800 cl9 4GB VALUE Plus Dual Channel RAM kit for only £35.99 inc VAT and free delivery to those who qualify. Designed with Sandybridge in mind this Dual Channel kit is perfect for those looking for an ideal match for an Sandybridge system or to accompany any other DDR3 based system offering fantastic value with compromising on performance.
Asus GeForce GTX 460 Direct CU TOP 768MB GDDR5 PCI-Express Graphics Card @ £113.99 inc VAT
Built from the ground up for DirectX 11, GeForce GTX 460 delivers the ultimate next generation gaming experience. With up to 4x the DirectX 11 tessellation performance of the competition, GTX 460 packs highly detailed visuals into your games - without sacrificing high frame rates. And with NVIDIA 3D Vision, PhysX, and CUDA technologies, GeForce GTX 460 powers all the incredibly realistic effects that your games can throw its way.
- Exclusive Voltage Tweak Technology
- Core Clock: 700MHz
- Memory: 768MB GDDR5
- Memory Clock: 3680MHz (Effective)
- Memory Interface: 192-Bit
- Processing Cores: 336
- Shader Clock: 1400MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.4a
- SLI Ready
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- Warranty: 3 Years
Only £113.99 inc VAT.
ORDER NOW
GeIL 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz VALUE PLUS Dual Channel (GVP34GB1600C9DC) @ £35.99 inc VAT
GeIL announces the launch of the all new DDR3 Value PLUS & Ultra PLUS Series to be added to GeILs’ high performance memory line of products. The Value PLUS & Ultra PLUS are equipped with the latest PLUS Edition memory heat-spreader designed with heat-sink surface and extended height for maximum cooling efficiency. The Ultra PLUS line of memory will be carrying over-clocking performance while the Value PLUS line has the more stability-oriented specifications. As GeILs’ quality standard, both series will be enhanced with DBT – Die-hard Burn-in Technology for the highest quality assurance.
- PC3-12800 1600MHz CAS 9-9-9-28
- 240pin, Non-ECC, Un-buffered DDR3 DIMM
- Aluminum Heat-spreader
- 6 Layers Ultra Low Noises Shielded PCB
- 1.4V-1.6V Power Supply
- Lifetime Warranty
- DBT - Die hard burn-in technology (Improved reliability)
- Sandybridge compatible
Only £35.99 inc VAT.
ORDER NOW
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- Warranty: 3 Years
ORDER NOW
- Lifetime Warranty
ORDER NOW
. Might snap a set of this up!
