ive took all the guides and spliced one easier to follow one together, what i posted before gave me a headache and i wrote it
1. Make sure your device is rooted.
* The first step is to launch Market on your HTC Desire HD.
* Once you are in Market, search for VISIONary and install the app.
* Once you are through installation, you will see a yellow VISIONary triangular app icon on home screen.
* Now launch the VISIONary app, temproot and then hit attempt permaroot. the device
should restart, disable temproot in visionary and reeboot you should have permaroot. to check download
terminal emulator from the market, enter su in the input, after you hit enter you should see #, if you do yoour rooted
2. Download "Android Terminal Emulator" from market, if you didn't do so already.
2a. download the .zip from
LINK 1 and extract the DHD-smart folder to the root of your SD rename it to DHD.
2b. Open Android Terminal Emulator and enter the following:
su -hit enter-
-then-
(Please be aware that You have to type "sh" in front of command)
sh /sdcard/DHD/check -hit enter-
If everything went OK type
sh /sdcard/DHD/backup
If this also went OK proceed with
sh /sdcard/DHD/hboot
This command will install engineering hboot which have S-Off turned off.
3. Install custom recovery image
3a. Since ROM manager now officially support's Desire HD, we will use it to download and install custom clockwork image.
3b. Run android market app on Your DHD and download and install ROM Manager app from market.
3c. Download and install ROM manager.
3d. Run ROM manager and select first option (Flash ClockWorkMod Recovery).
3e. Wait until ROM Manager say's that installation went successfully (Current version of ClockWorkMod is 2.5.1.3)
3f. After installation tap in Rom manager option Reboot into Recovery to test that everything went well.
3g. DHD should reboot in clockwork recovery manager.
4a. download the ud-cm7-RC0-DHD-PNK12b.zip rom from
LINK 2 dont unzip just copy to the root of your sd card, make a note of the name.
4b. download the FULL WIPE from
LINK 3, dont unzip, move the file to the root of your sd card
5. go to rom manager and select reebot into recovery mode
6. To backup your existing ROM, apps and data, take a nandroid backup, use the volume down key to move to the backup & restore and hit the power button, select back-up and wait for back-up to complete.
7. go back to the main menu again and select ‘install zip from sd card’ select 'choose zip form sdcard' Select the FULL-WIPE-1.2.Zip that you copied to your SD card in step 4b, and wait patiently while it is flashed to your phone.
8. now your phone has been clean wiped, Get back to the main recovery menu and select ‘install zip from sd card’ then 'choose zip form sdcard'. Select the gingerbread ROM you made a not of earlier that you copied to your SD card in step 4a, and wait patiently while it is flashed to your phone.
9. Once the flashing is done, reboot your phone
you will need to reebot once more before wifi works.
--LINKS--
LINK 1
LINK 2
LINK 3
