Don't waste your time, it's not single slot.
http://www.overclockers.co.uk/showproduct.php?prodid=GX-185-XF&groupid=701&catid=56&subcat=1515
Foot/mouth?
No single slot 460 on ocuk though, pity.
Galaxy gtx 460 razor edition however if you seriously want one I suggest you grab one now, they're limited like last time.
Foot/mouth?
They aren't low profile, they're single slot.
This is low profile: http://www.overclockers.co.uk/showproduct.php?prodid=GX-023-HS&groupid=701&catid=56&subcat=
and thast also agp ( ok i never stated what i wanted lol ) amd at least 1 generation behind the 5570....
so lloks like the 5570 is about it then ?
GTS 250 low profile cards exist.Just found a bunch now. The benefit is very mature drivers, so there is another option into the mix.
The GTS 250 would not have been much faster than an 8800GT - probably about the same speed. It will have lower clocks as you take a hit with low profile cards.
Since that has a heatsink that's too big, and the 5670 does as well by the looks of it, I think you won't get a better performing card in low profile format than the 5570 you initially mentioned.
http://www.overclockers.co.uk/showproduct.php?prodid=GX-226-SP&groupid=701&catid=56&subcat=1699
would seem like that..... unless someone has got one those in my case ( spec )
i'm assuming the 5570 will be miles better than inbuilt 4200 onboard ?
