People have always read on the internet that the only true figure is the power at the wheels figure, that the power at the fly figure is a figure generated to massage people's egos by looking bigger. And that the only true indication of a car's power is the power at the wheels.
The american's are very much in this mindset, its not uncommon to hear people on american forums talk only of RWHP - rear wheel horsespower. Very rarely do they quote crank horsepower.
However in europe we nearly always quote the engine power instead of the power at the wheels. As a result the Maha dyno that powerstation use has been geared up to produce a more accurate engine horsepower figure by using two rollers. Whether you believe this works or not is up for debate. I've no idea if its true or not, but thats what Maha who make it think.
Because the wheels have two contact patches, there is more resistance at the wheels than you would get in a real life. You could possibly choose to take account of this, and quote an accurate power at the wheels figure, but powerstation choose not, and use it purely as a figure for calculating the crank horsepower.
However, because people see power at the wheels figure that are horribly inaccurate, they conclude that the dyno itself must be horribly inaccurate also. This is not true, the Maha dyno that PS use is not intended to quote accurate power at the wheels figures. It quotes it on the graph purely for reference. Maybe they should remove it to avoid confusion ? who knows. Its german and you know what those crazy germans are like ...
But anyway, main point is the Maha Dyno doesnt produce accurate power at the wheels figures and aims instead to produce accurate power at the flywheel / crank figures.
Good point. It makes people with 4WD feel better, because they can loose so much power through the transmission.
The dyno has only one point of reference, the power at the rollers. This figure is deemed by most to be inaccurate. How that inaccurate measurement can suddenly become an accurate at the flywheel figure just doesn't equate. If it is simply a correction factor or something then why not have it applied instantly so that you see an accurate ATW figure?
I have a new SX which I have modded but still! have boost leak issues, will still be nice to get a baseline.
of course i did, my post was entirely related.
