Best Cooler for X2 6400
22 Feb 2007
Sunderland, UK
Hey people.
Basically my Cooltec CPU cooler doesnt seem up to it.
Idles around 58C peaks at 79c and its not even overclocked.
Simple question;
I want a cooler that is fairly quiet and keeps temps down,
For an AMD X2 6400 Black Edition.
From your experience what is good.
Cheers,Aly
80C is way too high for your CPU. 63 max temp.
You probably, I mean obviously do not have the cooler seated correctly. Reseat it and apply a newer thermal paste. I suggest IC Diamond.
If you insist on a new cooler, what Grimley suggested is fine. But if your case is quite small, go for this instead: http://www.overclockers.co.uk/showproduct.php?prodid=HS-039-AR
Thanks mate,
It is seated properly no idea why my cooler is useless.
In my sig it says I use an Antec 900 case :p
