computer builders.
11 Jan 2011
Hi, i have decided on my spec but i need a computer builder to build it for me as i dont think i could.
i assumed overclockers would build it for me but i have been told they want and only will make slight adjustments to they're computers.
not sure if this is allowed but can someone list a few computer builders.
private message me if prefered. :)
To be honest, its much more beneficial for you if you learn how to do it yourself, its quite simple tbh, you may be able to find a decent guide on google, sorry =/ got the lazy bug.
I could help if you're near me. Sure other forums members would do the same!
Failing that, there are plenty guides on the internet, and you can even buy books telling you how to! :eek:
i would like to build myself but im a bit wary incase i mess things up.
heres the spec
CASE - Silverstone Fortress FT02B with AP181 fans
FAN CONTROLLER - NZXT Sentry LX LCD Fan Controller
PSU - Corsair HX 850W ATX Modular SLI Compliant Power Supply
CPU - Intel Core i7-2600K 3.40GHz Overclocked to 4.5GHz
CPU COOLING - Thermalright Silver Arrow
MOTHERBOARD - Asus P8P67 PRO Intel P67
MEMORY - Corsair XMS3 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit
GPU - Zotac GeForce GTX 580 1536MB GDDR5 PCI-Express Graphics Card
HARD DRIVE 1 - Crucial RealSSD C300 128GB 2.5" SATA 6Gb/s Solid State Hard Drive
HARD DRIVE 2 - Hitachi Deskstar 7K2000 2TB SATA-II 32MB Cache
OPTICAL DRIVE - LG BH10LS30 10x BluRay-RW / 16 x DVD±RW Drive
CARD READER - Akasa BayMaster Card & Drive Reader
OPERATING SYSTEM - Microsoft Windows 7 Home Premium
i live in south wales but i dont think there are any local builders that will do this so having it sent to me will be my only option i think. :)
heres the spec
Niiiiiiiiiiiiice system!
PLenty of guide on the net, check out the Bit-Tech website - there's a good one there!
Newport, Cardiff, Swansea, Haverfordwest? Come on give us a clue ;) There's a fair few miles between Newport and Haverfordwest.
If you really don't fancy building it yourself have you not considered buying one of overclockers builds? Something like this might suit you?
I understand your point being a bit wary to build it yourself, it looks expensive. But if you are unable to find anyone, im sure if you took your time and posted any problems or questions in detail on these forums you would get through the build with no problems at all :)
why not just build it your self, its pretty simple just take your time and read the guides that come with the mobo, + you will have more satisfaction from it, i'v just built my second rig, and it took (dont laugh!) 5 hours, but thats because i read everything jsut to be sure as i spent quite a lot on it lol plus there was the cable managment !
Have a look at all the guides on the net. Take your time and read through the instructions a few times. Everythig goe sin one way round, it can't be difficult as there are now so many people doing it.
I was going to see if you wer near me and then offer to help; after seeing your spec list It turned into a no way incase I break something! The silver arrow may b the most difficult bit
That's a pretty expensive computer; I'm certain they'll assemble it for you. If you get through to a monkey, escalate to management.
It'll help if you pick whichever prebuilt looks most like it and then propose a long list of adjustments to it.
There's no shame in not assembling it, some people are mechanically inclined and others aren't. It can also be an expensive learning curve.
