Pictures of the Asrock p67 extreme 6 motherboard
Caporegime
27 Nov 2005
Guernsey
Thought i post these pictures for anyone that maybe interested in this motherboard..
(These are the pictures from the review linked below )
Asrock website http://www.asrock.com/mb/overview.asp?Model=P67 Extreme6
Asrock p67 extreme 6 Review http://translate.google.com/transla...restazioni-alla-portata-di-tutti.html&act=url
Awesome looking mobo, perhaps Asrock are the new Asus, + there youtube Asrock techs are hilarious at work :)
Heres hoping Ocuk stock the new extreme Asrock P67 board coming soon...
6 fan connecters...(2 above CPU socket,2 above sata sockets & 2 at bottom left) :)
But don't like where they put the 4 pin molex socket..
Thanks mate.
Also wondering whether a Noctua U12P would fit this thing using the socket 775 mounting holes - ASRock claims the board is compatible with socket 775 coolers, but Noctua's compatability guide says you need a 1155/1156 adapter. I can't tell if it's just Noctua playing it safe, or if there's some sort of clearance issue when using the 775 holes.
Any word on whether the ASRock BIOS allows control of 3-pin fans?
Though this motherboard provides 4-Pin CPU fan (Quiet Fan) support, the 3-Pin
CPU fan still can work successfully even without the fan speed control function.
(From the Manual) Looks like it doesn't.
Thanks mate.
Sorry i can't help you on this one..
As i have one these Zalman coolers coming with my board http://www.overclockers.co.uk/showproduct.php?prodid=HS-054-ZA&groupid=701&catid=57&subcat=1395
(But i am hoping that my socket 775 D-TEK waterblock will fit as am thinking of going back to watercooling)
I'm going to go with no on the 3-pin fan control. Not sure if that means there are any motherboards which still have that option.
That's a shame. Will have to use a PWM Y cable to connect the 2 cpu fans to the 4 pin cpu header. My intakes will run from molex anyway and have speed switches. Just the one exhaust fan I guess I won't be able to control then.
Why have 1 x 4 pin cpu header and 1 x 3 pin cpu header if you can only control one? Surely most people that have 2 cpu fans will have 2 the same!
