- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys
Titan Hati CPU Cooler @ £39.98 inc VAT.
TITAN introduces the Hati, a member of its FENRIR cooler family known for their powerful heat conductivity. Hati is equipped with a 12cm low-noise fan with high air volume. Its unique heat sink design allows users to mount one or two fans according to their preferences.
With triple u-shaped heat pipes and direct contact core technology, Hati takes the advantage of enhanced heat conductivity to generate sufficient cooling power. Fully compatible with Intel and AMD systems.
- 3 x 8 mm heat pipes with direct contact technology to maximize heat conductivity
- PWM function fan with automatic speed adjustment according to the temperature of CPU for extra-silent operation
- 12 cm Kukri shaped fan for efficiency and silence
- Include 4 vibration reducing mounting rubber bolts and has the option to equip one or two fans
- Compatible with Intel LGA 1366 / 1156 / 775 & AMD AM3 / AM2+ / AM2
- Fan Speed: 800 - 2200RPM
- Fan Airflow: 24.2 - 66.6 CFM
- Noise Level: 15-35 dBA
Only £39.98 inc. VAT
BUY NOW
BUY NOW
