Excuse my ignorance, but what do: Bloom, HSAO, Aniso and Fov do?
I have Bloom=True, HSAO=false, Aniso=2, Fov=55.
I sometimes get slugging performance in smoke, but generally it's ok. Plus, should I have my DXVersion set to a specific one? Currently it's auto. If I can boost the framerate, without reducing quality, then I'm happy to have a fiddle.
I'm using a Phenom x4 925 @ 2.8, 1gb 5770.
Try bloom on false (its responsible for some of bfbc2s glare) FOV is field of vision. Which is calculated horizontaly, there was a calculator for that somewhere) and try setting DX to 10. On auto it will will be on DX11 with a 5770 so see if DX10 gives you a performance boost.
Bampot![]()
Nah more likely a new mod that instantly slays snipers when they fire without bothering to tell them its restricted. Was a server a few days ago that appeared to be autoslaying people who killed infantry with a rocket launcher, no idea if that was the case as i never tried but a big server message would pop up on screen saying player x had been slayed for abusing the RPG. Mods that restrict them just kill you instantly if you've gone over the limit.
but if i pistolled someone i wouldn't... very very very odd, th guy i was playing with said it happens its a common bug... ?!
Given that they've nerfed the CG/etc massively I don't really see the issue any more. People using them will get a few cheap kills but in the meantime the assault rifles and engineer weapons are out-killing them at a massive pace.
Now to search back through the thread and try and find the advanced bc2 config thing![]()
I've seen a server that locked Recons completely, wouldn't let them spawn full stop, which should definitely be changed to unranked. But then this was clearly a **** server given that it had 10000 tickets... Servers that play 16v16 but lock Recons to 2 or 3. Servers that restrict Gustavs to 2 or 3 people on maps with Helicopters meaning you can't use it to take down a chopper because some retards are taking it for infantry.
And yeah blanket slays for killing infantry is dumb. Would basically mean if you RPGd a tank and the guy bailed as it hit and killed him you'd be autoslayed.
Well they nerfed Gustavs but the idiots running round with double ammo and MK2 still get easy kills. I switched to that on 1 Cold War level and it was pitiful how easy it was to get kills/double/multi.
Always go with the RPG as I fire it at vehicles....![]()
