- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys,
Most of you won't be aware of the new coolers on the horizon, but we have them for pre-order now.
The advanced will be here in 4-5 days and the Pro will be here the following week.
BeQuiet Dark Rock Advanced CPU Cooler (Socket LGA 775 / 1155 / 1156 / 1366, AM2 / AM2+ / AM3 / 754 / 939 / 940) @ £39.98 inc VAT
The Be Quiet! Dark Rock Advanced combines maximum cooling efficiency with a pleasantly quiet operation. With an extremely low noise level, efficient cooling is provided for gaming, multimedia and CAD systems even at maximum processing power. This CPU cooler is enhanced by the high-quality materials used, as well as its attractive design.
- The single-tower layout with six heat pipes enables excellent heat dissipation within a small space
- The 120-mm SilentWings PWM fan guarantees the best ratio of cooling efficiency to noise level
- The wave-shaped contour of the cooling lamellas prevents noises and optimises the airflow
- The fan surfaces are coated in dark nickel
- The brushed, fully aluminium cover protects the cooling lamellas
- The stable backplate ensures a shockproof attachment, even when transporting the computer
- Extremely efficient up to more than 180 watt
- LGA 775 / 1155 / 1156 / 1366, AM2 / AM2+ / AM3 / 754 / 939 / 940
- Fan Noise: Upto 18.8dBA
- Air flow: upto 85.8 CFM
- PWM Controlled
- Dimensions: 122 x 95 x 167 (L x W x H)
Only £39.98 inc VAT.
ORDER NOW
BeQuiet Dark Rock Pro CPU Cooler (Socket LGA 775 / 1155 / 1156 / 1366, AM2 / AM2+ / AM3 / 754 / 939 / 940) @ £54.98 inc VAT
The Be Quiet! Dark Rock PRO combines maximum cooling efficiency with a pleasantly quiet operation. With an extremely low noise level, efficient cooling is provided for gaming, multimedia and CAD systems even at maximum processing power. This CPU cooler is enhanced by the high-quality materials used, as well as its attractive design.
- Two 120-mm SilentWings PWM fans guarantee the best ratio of cooling efficiency to noise level
- The brushed, fully aluminium cover connects the fan to a closed unit
- Extremely efficient up to more than 220 watts of cooling performance
- Noise Levels: 12-25 dBA
- Fan Speed: 1700 RPM
- Air Flow: up to 93.3 CFM
- PWM enabled
- Dimensions: 133 x 150 x 166 (L x W x H)
Only £54.98 inc VAT.
ORDER NOW
- PWM Controlled
ORDER NOW
- PWM enabled
ORDER NOW
