WATERCOOLING CLEAROUT DEALS! GRAB A BARGAIN TODAY!
11 Dec 2005
Cheshire
We have a lot of fantastic deals on clearence section watercooling. Fittings from 72p!
OcUK Value 1/2" barbed fitting G1/4 with O-Ring (Perfect Seal) @ £0.96 inc VAT
The perfect seal fittings ensure, as the name implies, a perfect seal with 1/2" hoses (approx. 13mm inner diameter). A hose clamp is usually not required, as the fitting has a large outer diameter.
Technical data:
Thread: G1/4
Compatible to hoses with an inner diameter of 13mm (=1/2")
Inner diameter of fitting: 1cm
Only £0.96 inc VAT.
ORDER NOW
Bitspower Adapter G1/4" to 11/8mm (BP-BSWP-C11J) @ £1.44 inc VAT
Only £1.44 inc VAT.
ORDER NOW
Bitspower Rotary Fitting "Q" - 360 Degree Water Cooling Accessory (BP-QR-C) @ £3.60 inc VAT
Bitspower now offers a chromed brass "Q" shiny fitting accessory to use for tight water-cooling situations. This is a Premium metal piece that is perfect for SLI on the bottom graphics card water block for bottom mounted PSU type cases and other tight spacings.
- Special Design for PC Water Cooling
- Perfect Surface treatment
- Real Hi-Flow
- Hiding O-Ring Design
- 360 degree Rotated
- Fit All Bitspower Compression Fittings
- Material : Hi Quality Brass
- Thread : G1/4"
- Inner G1/4" Thread No. : 3
- Chromed Brass 360 Degree Housing (Fittings Optional)
Only £3.60 inc VAT.
ORDER NOW
Koolance QDC (High Flow) Barb G1/4" To 3/8" - black nickel @ £0.72 inc VAT
Only £0.72 inc VAT.
ORDER NOW
Does this mean you will be getting more fittings?
I'd like to see a full range of Bitspower compressions as I cant seem to find anyone that stocks the normal ones as well as 45 and 90 fittings, I'd have to buy from 2 or 3 places to get all the fittings I need
+1. Please get in some black bitspower 1/2" compression and rotary fittings. :)
I would prefer them to stock an entire range of something like EK products, im looking to do watercooling but its impossible to put a complete loop together from products from OCUK.
While you're on about your cheap fittings I think you could do to check your descriptions of some of the fittings in your main water cooling section. I almost made the mistake of buying these...
http://www.overclockers.co.uk/showproduct.php?prodid=WC-043-BP&groupid=962&catid=1529&subcat=
The item says they are for 3/8" tubing but the description says they are for 10/8mm tubing. At 24p a shot I'm willing to bet a fair number of people could impulse buy them thinking they are for normal 3/8", i.e. 9.5mm ID 12.7mm OD. I mean, I nearly did.
Nath any ideas if your going to be getting any stock on the EK Supreme LT AMD, can't find stock anywhere and dont wan't to spend £60 on the HF. Not bothered if its nickel/copper/acetal I just need something better than my XSPC Delta
Is there a problem with the ordering system, I'm trying to buy something from the clearance section and I'm getting "Sorry, but the payment process has failed. Response:" when trying to confirm. When the web page reloads when you click confirm the font size increases as well for some reason.
To be honest, probably not anything soon. As AMD exclusive heatsinks/waterblocks sell fairly poorly. I can get one shipped in just for you but it won't be a product that we stock in any numbers. Sent me an email and I can get you sorted :)
Is this on any particular product? Working fine our end :confused:
Trust email is that Nath, assuming it'll be around £32 as thats what competitors have them for?
Ta very much, can't beat OCUK for outstanding service.
Could you tell me what the stepping code is on the Athlon 64 X2 Dual Core 5200+ as well if possible?
