- 10 Jan 2011
Hi, I've been looking to build a long-term PC for what seems ages now, and after finishing Uni I feel like treating myself.
I've been reading up since September last year, and eventually decided to wait until Sandy Bridge came out before I pounced!
As the title says the system is going to be used for a whole variety of games, with standard web browsing and watching some films too.
Build is as follows, with a few missing bits...
(Already have a Logitech G15, Logitech MX 620, Boogiebug mousepad, Goldring NS1000 headphones + FiiO E5 so just need the PC/monitor to go with it!)
I like the styling of the Phantom and I've read good things about the airflow/noise/cable management so quite happy with that choice.
For the monitor, I've gone 3D with the thoughts that I can enjoy some games/films in 3D, and even if I'm not using the 3D, I still have the 120hz to give it a nice little edge.
With the other choices being quite straightforward.
The areas I'm looking for advice about are (although if there are any thoughts about the previous feel free to say):
Cheers.
- SSD
My thoughts were that I'd use the SSD as a boot drive with my mostly-used programs on, with the HDD as the storage drive - with most games installed on. Is 60 enough, or is it worth looking at 120? - RAM
Here I'm not sure whether to go 4 or 8 Gb. I've read that for most use 4Gb will be more than adequate but was wondering where 8Gb would come into play, and if its worth going for 8? - GPU
Looking at going for a 570 as it seems a solid card and I don't fancy paying the premium for a 580. Plus for the 3D it seems the right choice. Just wondering which to go for? - PSU
As I'm looking to overclock both the CPU and GPU, plus possibly add a 2nd card in SLI in at a later date, which modular PSU/s should I be looking at? - Win7
I'm not 100% on whether I need a copy as I have previously purchased a Windows 7 Home Premium copy when I was still a student to replace Vista on my laptop.
Through checking the Product ID there is no OEM within the code, only numbers, which I think, proves it is retail? However it is 32-bit on my laptop and not sure if this means anything, so am I ok with this copy?
Cheers.
