white & blue water cool time.
28 Oct 2010
Colchester
Hi guys!
I have been wanting to watercool for a while now so I have decided to go for it, i'm also sending my case off to be powered coated as well.
I am planning on watercooling my i5 760 in my Lancool K-62. This is my first watercooling build so go easy on me . Anyway.
my watercooling gear I have bought is as follows
Tubing: PrimoFlex Pro white 7/16 hose
Pump: Swiftech Laing D5 Vario MCP655 12V DC Pump
Radiator: Black Ice Stealth 360
CPU Block: The heatkiller CPU Rev3.0 LT (white)
Coolant: distilled water
Reservoir: XSPC Single Bay Reservoir
Fittings: 1/2" Chrome Barbs
Thermal Compound: Arctic Silver 5 (3.5g)
Fans: 3 Akasa venom 120mm.
Others: silver Kill coil, Hose clamp 1/2inch & PrimoChill Liquid Utopia
My pc hardware what i have is:
Cpu: i5 760 overlclocked to 4ghz
Mobo: MSI P55-GD65
Ram: Corsair XMS3 4GB DDR3 @ 1600MHz
GFX: ATI 5850
Storage: 2 x 1TB hdd
PSU: Antic true power 650w
I do apologise for some crappy pictures as these was taken from my phone.
Here is the build before I start.
My case all empty now, being sent off later to be powered coated white.
All my other components
messy cpu, but it's all clean now.
Just to show how big the akasa venom cpu cooler is
That's what i have for now, my case should be back by the end of the week, during this week i will be flashing the rad
and mounting the water block so there will be more picture as soon as i do them.
thanks for looking.
This will be interesting. Good luck!
By chance, have you already bought your wcooling parts? Because I'd recommend getting 7/16" tubing and getting distilled water instead of that primochill stuff :)
hi guys,
Yesterday i got round to flushing the rad, I flushed it about 8 times with malt vinegar. over the next few days i should hopefully
mount the cpu block and start to cut out the plastic top of my case so the rad sits flush on the top of the case.
here are a few pictures of it:.
looking a lot more better
before and after...
i'm hoping this will all be done by Saturday night, it's all depending if i get my case back from being powered coated.
thanks for looking..
hello guy's,
i've now got my case back from being powered coated and it look's really gr8 n i'm happy with it :)...
I should hopefully have everything installed 2day ready for leak testing.
here are the picture of the case.
more updates as hopefully 2day..
I really don't want to sound rude but just out of interest how much (roughly) did the powder coating cost? I am thinking of getting a TJ07 and powder coating but have no idea how much it will roughly cost.
Cheers
Cheers
£42 inc vat.. There's a place Down the road from me wat does it....
Nearly done now. Pic will b up soon.
hey guy's,
I'm now all done and dusted!... and it looks sweet!.
here are the picture:
all fitted in the case now!, looking sweet!
leak testing
all set up and running..
i am really happy woth the out come!, hope you guys like it and let me know what you think as this is my first time doing it.
I will put more picture's up 2morrow with the temps before and after water cooled
