Snow Leopard
18 Oct 2002
Bristol
I never did bother upgrading to Snow Leopard, just seen that discs are pretty cheap on ebay, is it worth it from Leopard? What are the advantages?
I'm running a 2.0 C2D Macbook (first C2D version) with 2GB and a 320GB 7200rpm drive.
if you don't upgrade to snow leopard i wouldnt be surprised if you are then unable to upgrade the lion and have to buy the Mac Box Set for £100 +
Snow Leopard was a unique upgrade only methinks. Lion likely be a full fanfare release. Even if not there has been to date no upgrade checking even on Snow Leapard.
It's a must, I have a similar spec Macbook Unibody (first aluminium model) but with a 160gb (?) drive...I had just got it and it came with leopard and then about two weeks later snow leopard came out. Popped to the shops, £25 in hand, difference is amazing...multi tasking felt so much better. :)
Okay, I'll do it. What are the pros and cons of upgrading against clean install. For Windows I'd only ever consider a clean install, but for OS X is an upgrade a reasonable thing to do? Will it delete all the unneeded Leopard code and free up HHD space?
I can't remember now but I think I just used time machine to back up my leopard install and then installed snow leopard and used the install with time machine option in the installer (once rebooted).. then just left it to it.
So long ago I can't remember lol.
forget all you think about the word "upgrade" that you remember from the days of how windows upgraded an OS.
its not
Its merely a licensing term.
An upgrade on OSX is a completely different kettle of fish and is fine.
When i upgraded to Snow Leopard it actually feed up about 5gb in space ! never saw a windows upgrade do that lol.
'upgrading' Leopard to Snow Leopard effectively does an archive and restore anyway. Just do it.
Yeah - just accept the default install. I forgot about the slimming effects of Snow Leapord - but I had already done most of what it does with XSlimmer. No printer drivers, alternate languages gone, thin binaries.
Snow Leopard also reports disk sizes in GiB rather than GB - so your disk look bigger too!
Completely true. :)
So glad I switched to Mac for my personal computer...it's just so painless to do upgrades. At the time I was thinking about what it might do and will I have to reinstall everything even though I only had a hand full of downloaded apps. :o
