http://www.overclockers.co.uk/showproduct.php?prodid=MB-428-AS&groupid=701&catid=5&subcat=1692
Anyone got one of these? Whats it like for overclocking?
May I ask why you want to go X58?
I really would suggest going up to the P67 chipset. The P67 with a 2500K CPU or a 2600K CPU is a winner every time. The Giga P67A-UD4 is a peach.
Ram is heaps cheaper than tri-channel and performance is outstanding. Only upgrade worth doing in my view.
Well it will be cheaper for me to go SB, but im put off by reports of motherboard issues, especially with the Asus as asus are usually my brand of choice.
Bit off putter tho with the asus is people not getting PCI devices to work properly.
FWIW, I have both PCI slots in my P8P67 Pro populated with a Hauppauge Nova-T 500 dual DVB-T card and a Compro S350 DVB-S. Both are working without any problems![]()
