It's rather tatty, appears to have a seized rear caliper and no tax. It's had a new head gasket, timing belt, water pump and other things as well. Would'nt drop below £1600 and it was'nt anywhere near as nice as the 1.6.
Lovely engine to drive, complete git to work on.
Still have nightmares about doing all 3 cambelts.
Cambelt is 60k or 5/6 years so it should have been done by now. If not it's £385 for my local garage to do it
yup i payed £150 for it to be done on my 1.8.
On a 1.6 ZS???? Thats daylight robbery.
Nah.....not too bad a job, 4hrs or so, job done!![]()
what year did the mg's get them? mine was a 2003 and didnt have the better gasket, i fitted it when the original went though. As i understand it this isnt a cure but the newer gasket does help, much of the problems with the headgasket are a result of the cooling system layout and the stat being on the inlet rather than outlet, which is why on the freelander they eventually moved the thermostat, there has been kits around for ages to move the stat to the water outlet for the elise/exige.
Front belt is a doddle, it was changing the rear oil seals on the back head that almost drove me mad.
Then trying to wobble the cam a little to get the rear pulleys back on was a utter pain, don't think that bit is meant to be a one man job.
stay away from that one, never buy a rover thats had work done on the engine like that as sometimes they are just never right again.
The 400/45/ZS is probably the best of the range to get as the smaller ones usually have been hammered by boy racers, and the 75's are just too damn expensive for parts given what they are.
Also the 400/45/ZS were designed for Rover by Honda whereas the 75 was designed by rover themselves(Hence why the Chinese company that bought Rovers IP is selling 75's in China but not 45/ZS as Honda own the rights to them)
