Exactly how do I do that safely without causing any damage? I looked at removing the cage yesterday and couldn't establish how the rivets are supposed to come out (they look solidly attached to everything). So I bash the rivets out with a hammer? What's the flat head screwdriver for?remove the HDD cage with a flat head screw driver and a hammer (take out the rivets)
So am I actually breaking the rivet permanently, or..? Is there a visual guide to doing this anywhere, as I can't find anything much on Google. I don't really see (from memory) how the rivet head comes off or what that means.Put the screwdriver (slotted not philips) against the side of the head of the rivet, bash screwdriver with hammer which should pop the head off the rivet.
best and proper way to remove rivets is to drill the head off which cause less damage..
as for drill size usually the same size or larger than the hole the rivet sits in around a 4 or 5mm will be ample
