Aftermarket cooler for GA-P67A-UD3 ?
6 Jun 2008
Hi folks, could someone recommend a cpu heatsink/fan that will physically fit onto this board.. was planning on an Akasa Venom, but heard there can be space problems due to it's slightly smaller than usual ATX size and the closeness of ram sockets / capacitors.
Am talking of the basic UD3 here, not the UD3R / UD3P.
Thanks.
The Akasa Venom is an excellent choice, the Corsair A50 is also a good choice alittle more subtle looking if the bright yellow of the Akasa is too much for you :)
The Titan Fenrir fits fine on this board, but be aware the DIMM slot closest to CPU goes under the heatsink so don't think the RAM in this slot will be removable without taking heatsink off first.
Cheers
