You'll need to open some. There's a link earlier in this thread (easier to find via Google probably) with the list of ports needed.
You really don't need to open/forward ports unless you're running an extremely strict firewall setup (99% of people on here won't be).
edit: People that are having problems - what ISP and router are you using?
Glad you got the punkbuster sorted out mate... Sorry I wasn't around last night. But I will be on tonight and over the weekend if you're around?
No worries matey i'll be on around 11pm tonight as im at work, im off sunday so i'll be there all day long
Getting the hang of it slowly a few kills here and there, just trying to find what suit i prefer at the mo, im like enginner so far the most, i cant seem to find out how to drop medi packs when im a medic but i'll get there soon i guess lol
I'm With O2 and using the supplied router
thanks topgun for that, im still trying to get my 1st upgrade to major 1 i believe it is or something like that lol nearly there tho. I have only just found out about the "Q" spot. Do many people actually use this? im not to sure exactly what it does and how it works but i'll have to have a play around with it![]()
I often play as Medic with the G36 or whatever the late one is. Must admit that the amount of ammo makes it very easy for me to go up against 2 or 3 people at once and drop the lot of them. I always drop medikits for anyone around me and will run considerable distances to drop one at the feet of people that I see low on health.
On the defibbing issue, its a lose/lose situation for medics quite often. Usually I wont defib someone if I think they will just get killed immediately again, if we are under fire or if I think that by running out and defibbing them I will simply get killed and leave us in a weaker position in that location. The trouble is that then often the people will moan that they werent defibbed, run and defib them and then often people will moan that they didnt want to be defibbed because they either died again or wanted to change class. Just as with MMOs, playing the healer is often a thankless task.
On a sidenote, I tried those config edits mentioned a page back and my K/D ratio shot through the roof, I went from getting around 1:1 ratio to getting 3 or 4:1 last night. Will be keeping those changes![]()
Try this fix. When I used to use Be/o2 routers it helped with pretty much all games:
http://www.trickery.net/bb/showthread.php?t=51178
This is down to the cackness of the speedtouch routers rather than anything with o2/Be's connection. I advise getting a different router to be honest.
Just tried that but when i try and enter my router using Admin it doesnt work, SuperUser works though but gives me Access Error: 404 -- Not Found.
Some people don't bother. But try to get used to using it when you can.
It can be used too sport enemies that you didn't know were there. Also, it can get you points if the enemy you spotted gets killed by someone on your team.
But I don't think you run around spamming the 'Q' button as the action gets disabled if you press the button too much within a certain time.
it's admin then the pw is now the serial number of your router.
