- 27 Aug 2003
- West Midlands
Personally I fancy pizza as it will be morning pizza
Personally I fancy pizza as it will be morning pizza![]()
Whoops, just seen this. Stick me down as a possible runner. Don't really need it as I use the JRM Superflow for benchmarking, but lets put it this way, if you need the extra numbers to make it cheaper (or I get loads of stick from the gays for not running) - I'll run.
Skeeter a Westfield is 4 inches longer and wider than a normal Caterham you are more than welcome to try it out. I am 6ft 2 and 15 stone and have ample room. There are a lot bigger owners than me
O/T CoreKrogoth is the Core tag from CoreNation? Looks like a UT character in your sig. I was an admin over there for a fair while.
I would run....but I can't be bothered to do the work on the car in time, I'll fix it's issues when I need to later on in the year....plus it's only a 140bhp BMW, I, nore anybody else really cares about it being run.![]()
Same. My car has just been retired from being my daily doing a 35 mile commute, so needs a service, some things done to it and a dam good clean, and I dont know if I will have the time or funds. And an 8 year old Clio is hardly an epic car to run, lol.
